Pagina 3 di 4
Re: Restauro tornio ARGUS
Inviato: sab giu 08, 2019 15:25
Hi Tasos :I dont' understand the plate that you need because the plate in foto is not engraved ,I suppose that is only the cover of norton box.
Inviato: sab giu 08, 2019 15:40
da tasos
CARLINO ha scritto:Hi Tasos :I dont' understand the plate that you need because the plate in foto is not engraved ,I suppose that is only the cover of norton box.
in my tornio the cover have the feeds and speeds for diameter and threats.. but the numbers have deleted by the use
look closer the next photo
Inviato: sab giu 08, 2019 16:43
That position is very bad for a table , is better a vertical layout : I think will be very difficult to find a photo of this table...
Inviato: mar giu 25, 2019 13:25
da tasos
hi again
finally i found a friend of friend how had the same gearbox with clean table on bigger tornio named ARIS !!!
please can anyone tell me what set up is for metric threats ???? because the table is Italian language.
thank you in adnvance guys
http://meccanicaedintorni.morpel.it/php ... w&id=77562
http://meccanicaedintorni.morpel.it/php ... w&id=77561
Inviato: mar giu 25, 2019 13:55
I don't know if this lathe have the same gear box : probabily external box is the same but inside the gear could be different. The first photo have the metric thread up and down Withworth, the second (the first part of plate )have a strange indication : diametral, modulo, decimali and I don't know if the numbers are pitchs or not.
Inviato: mer set 09, 2020 21:15
da TEOPAOK
taso tha ithela diastasis gia ta granazia 30 kai 95 exoteriki diametro akribos to mono gnosto einai to mondul 1.75
Inviato: mer set 09, 2020 21:19
da TEOPAOK
ean o filos ta exei na mas eukolini gia na kano nea giati mou lipoun
Inviato: mer set 09, 2020 23:01
Adesso scrivono anche in greco.... :risatina:
Inviato: mer set 09, 2020 23:13
da carlo1974
sono i compagni di campeggio di albarello...
Inviato: gio set 10, 2020 09:35
:risatina: :risatina:
Inviato: gio set 10, 2020 11:42
da Dasama46
Logarismòs , parakalò . . . . :risatina:
Inviato: gio set 10, 2020 13:14
Λογαρισμως ,παραkαλο....
Mario , almeno usa l'alfabeto giusto..... :risatina:
Inviato: gio set 10, 2020 19:53
da Dasama46
Inviato: sab set 19, 2020 21:27
da TEOPAOK
si prega di diametro per ingranaggi 30 e 95 modulo 1.75 tornio aris
Inviato: sab set 19, 2020 21:36
da TEOPAOK
Grazie in anticipo
